pigmode
Truck-Fi
- Jun 26, 2001
Yup, egg/chicken unfortunately.
I'd like to see comparisons between the OR4 and A2/w psu.
Originally Posted by leeperry /img/forum/go_quote.gif
Yeah, what we need is an affordable USB transport that outputs isolated I2S...when the market is flooded to death w/ coax, I can't seem to find any $500ish non-DIY/kludgy USB to I2S solution w/ serious clocking at all. The market needs to move on, I2S is the future. You can't isolate 480 MBit/s USB and S/PDIF is a highly flawed protocol(due to the slave mode clock recovery), so this strives for a more foolproof solution IMHO. Ah well, most DAC manufacturers go for a quick buck and don't care for I2S...so this will all end up being an egg/chicken situation I guess
Perhaps the issue is the lack of budget DACs with I2S? I think it's just newer tech and will take some time for the market to mature.
Clean USB out of PC
Is there any kind of consensus about how to get the cleanest signal possible over USB out of a PC? Some methods:
SOtM tX-USB PCI - So I undertand that this FILTERS out noise, but does it do anything for galvanic ISOLATION. Does it need to. There have been mixed results with this card because some say you have to manage IRQ in order for it to sound good. How does one ensure this device does not share IRQs with other devices.
USB Isolator - Like the Olimex provides galvanic isolation but does not filter. Does it need to. It can only pass audio up to 96. Can be bus powered or grid powered. Which is better? Does it matter.
AQVOX USB PSU - I understand that this will help provide clean power to a bus powered device like the Audiophellio2, but does not provide galvanic isolation. Is it necessary?
USB Hub - Like the Vaunix Brick USB Hub. Provies a solid power supply for Bus powered devices but does it provide galvanic isolation? Does it need to?
USB Cable w/ No Powerline - Does a USB cable with the powerline cut achieve the same thing as galvanic isolation. Bus powered devices would need their own grid power like the AQVOX. Is this enough?
Is any one of these items enough to clean the USB signal path or does it take a combination of devices? Which ones?
I have been trying out the Audiophilleo2 and can say that the sound quality of the unit is certainly effected by the signal it receives. Is the John Kenny JKMK3 any better at cleaning the signal? Does it provide galvanic isolation Does it filter out noise?
Any help would be greatly appreciated.
I2S is not new(circa 1986), S/PDIF is several decades old too...it's all going so sloooow =/
I think the issue is that all of these USB isolators only work at full speed USB not high speed, so the limiting factor is the speed that the isolator will allow.
IMO I havent seen any indication why the green key is any different to other USB usb isolators apart from who made it.
The original USB 1.0 specification, which was introduced in January 1996, defined data transfer rates of 1.5 Mbit/s "Low Speed" and 12 Mbit/s "Full Speed".[3] The first widely used version of USB was 1.1, which was released in September 1998. The 12 Mbit/s data rate was intended for higher-speed devices such as disk drives, and the lower 1.5 Mbit/s rate for low data rate devices such as joysticks.[4]
Good point though about checking the capabilities of devices, however it's mainly an issue with S/PDIF and AES converters, as not all have the necessary clocks to handle the different audio rates (44.1, 48 and multiples of those).
Where would one look for that Hynes linear PS? And what type exactly would be needed for the Vaunix?
I found his site, thanks.
I see he has a 12V model SR1-12 Supply, but it's listed at 0.6 A so I guess that won't work?
As usual, implementation is everything. I compared several dongles on the Firestone Bravo(+Supplier DPS) and the Olimex sounded the best to my ears...but it wasn't either designed or specifically meant to be used on audio gear. This is the first commercial audiophile USB Isolator I'm seeing.
