AngryBaconGod
- Mar 3, 2011
$250 at accessory jack is the cheapest and best place to buy atm. Or maybe used ones around $200-220 ish.
Much appreciated!
I should be getting monster triple flange today from ebay:
http://cgi.ebay.com/earbud-replacement-tips-fo-Monster-Beats-Dr-Dre-Tour-N-/150419482729?pt=Other_MP3_Player_Accessories&hash=item2305b32869
these are fake right? would these tame the harshness a bit that I am getting with sony hybrid tips?
No, those will make your harshness issue worse. That tip has a large bore sound hole so it will pass through even more highs. If you want to tame the highs these will do it very well. Get the long stem version and trim to size. http://earplugstore.stores.yahoo.net/roauprtrflti.html
I am just glad that you were wrong
cheers!
these tips should have been the default...wow
Quote:I am just glad that you were wrong
cheers!
That's great. Did you snip the top or are you using them whole?
fake monsters are a bit softer. if you can't get a seal with them, you need a bigger tip. i get a perfect seal with mine.
