Danutz
- Feb 25, 2007
Could I use Dante Via instead of DVS?
Anybody tried with our Rednet's?
Thanks
Thanks
Did anyone replace the fuse in their RN3? I thought someone said they did, so I ordered a Padis fuse to try.
I got it today and am trying to figure out where to install it; well, the manual says "there are no user-replaceable fuses in RedNet 3" and I don't see a way to access the fuse. I'm assuming it is in the IEC socket but there's no opening or anything. Either that, or it's in the switch in front which is on lockdown. They filled in the gaps in the screws that hold it to the chassis so that it can't be removed.
Read on to see his verdict about the Mullards
I feel sorry for those folks who are trying all they can to dismiss the improvement in SQ that a lot of people here are hearing who already tried Dante RedNet AOIP compared to USB.
I for one was glad that I took the risk in trying the RedNet AOIP without even knowing what I was getting myself into and now am very happy with the results.
A big plus is also knowing that I will never ever have to buy any of the latest and greatest USB decrapifier device out there.
We will probably hear a lot more bashing and trashing of this new found (to audiophiles) technology but all I'll say is the fuse have already been lit on AOIP and from here on it will only spread like wildfire!
I'll say it again.
USB AIN'T GOT NOTHIN' ON AOIP!!!
Screen grabs of my latency tests (top 2), both software say PC is capable of streaming realtime audio.
Second screen grab shows latency at to be under 4ms which is considered good by Dante software, you can also see the settings for everything Rednet/Dante in that 3rd screen.
The last screen was the last step to achieve 24/192khz to work with my R3 and my slower 1.7ghz i7 over gigabit lan direct pc to R3 connect. First with the NiC enabled I unchecked everything and hit ok. Naturally the network card can not connect to anything without those services enabled. Then I turned them all on -- this was when 24/192khz became available to the Rednet. Then I started clicking things off one at a time to see which minimum set I need to run Rednet 3 and the last screenshot shows 3 items checked. I don't know what setting your setup this way will do to a computer hooked up over LAN that relies on other things besides feeding a Rednet with music so change this at your own risk.
Okay, first impressions of the Rednet 3:
- Holy crap, this is twice as big as my mind's eye told me it would be.
- Why the hell did they give me a brand new device with firmware so old it won't be recognized by what they tell me to download?
- Ugh, what a pain in the butt, this is taking forever, give me my music.
- Wait, after my manual firmware update you're updating the firmware again? Amateur hour.
- I regret my purchase. This is gigantic and a sloppy user experience.
- Okay, finally, it looks like I've made progress and just need to click a couple of channels to get things working.
- God damnit it sounds great.
Currently I'm just pumping 192kHz to my MHDT Labs Canary of all things because that's what I had hooked up. It may very well sound better than the Mutec MC-3+USB. I'm honestly afraid to chain that after the Rednet 3 now.
Now to find the settings @rb2013 experimented and landed on.
Patience grasshopper, patience...Lol!Okay, first impressions of the Rednet 3:
Damn son, sub 1ms..bravo!
Dayum.
I technically built my machine for gaming, but that translates to great audio performance as well.
Sample Rate: 192kHz
Dante Latency: 4ms
Buffer: 128 samples
Enconding: 24 bits / sample
Asio Latency: 1 ms
My machine's relevant specs:
CPU: Intel i7-4790K
Motherboard: Gigabyte Z97X Gaming GT
RAM: 16GB G.Skill TridentX DDR3 2400
Ethernet: Killer E2200 (Qualcomm Atheros)
