vpsporb
- Jul 18, 2010
Quote:Thanks for the mini reviews Tini and Zynaps.
Could somebody test the SPDIF vs Toslink inputs?
My SPDIF is being used for DD/DTS, so I'll have to use Toslink or USB from my PC to NFB-11.
But if SPDIF is clearly the best input, i'll have to change things.
Thanks
both coaxial and optical are spdif so i think you referring to;
SPDIF = Coaxial input?
Toslink = optical input?
Well sound from the coaxial and optical so be no different, and I found the USB equally good when i did a quick test with my NFB-12.
Oops, You're absolutely right... I meant Coaxial input.
I'm a little concerned, since Audio GD has dropped USB from their ESS DACS outright.
User opinions are that Coaxial is best implemented, the Toslink seems well buffered in pictures tho.
anybody else.....? Bueller?
