jehugo
- Mar 15, 2009
Thanks Dan
But if you want to make a better quality ACSS cable, send King-Wa a mail & he will give you the pin configuration for the ACSS cable, you can provide that to a custom cable maker & they will make one for you. I had mine made by Signal Cable.
http://www.signalcable.com
Unless spec has changed the ACSS is just mini 3 pin XLR.
You only need to connect positive & negative, no need to connect ground although I did because I already had the cable for it.
If I remember correctly pin 1 is ground so only need to solder to pins 2 & 3.
It took me 15 minutes, if you can solder
Did you get the Silver Resolution Cable?
The DAC to M9 is mini-Xlr but the ACSS connection from the Master 9 to Amp is a 4 pin XLR. People tend to forget that the M9 pre-amp section is even better than the Head amp section.
I have Silver Res cables through out my system (HP & Speaker).
IMO Compared to stock A GD cable the most apparent change was increased detail & clarity.
http://www.signalcable.com/
I asked Signal Cable if they can do an ACSS cable.
“Thank you for your interest, unfortunately we do not work with mini XLR connectors, as the openings are too small to fit any of our cables.”
