drez
- Sep 7, 2009
Lol I have the same problem, just tried the remote now, it doesn't work, though I don't care that much, it sounds terrific.
Have you tried changing battery?
There is no gain in ACSS except for the volume control AFAIK. Gain switches are for XLR and RCA connections.
I will soon.
Has anyone tried to change the power modes? I changed it and didn't notice any difference in volume with my Audeze LCD-3. So I was wondering if the following image is swapped or if it's swapped in my unit. ¿Does the gain switch do something when you're connected by ACSS? If it's doesn't then it would logic to expect the switches are swapped.
So the switches are inverted I see, thanks. ¿Does the LCD-3 sound better on high power mode?
Haven't measured the power output changes but moving from low to high power (even after the obligatory 10 second shut down) causes the amp to shut down using some cheap 45 ohm phones.
I can't tell how the switches are done because I have the Master 6.
Can't say if LCD-3 benefit from the extra power. You'll have to test and hear for yourself. Low power should be enough considering it's sensitivity, but I haven't tried it myself.
I will soon.
