PhaedrusX
- Aug 30, 2007
Does the tranport have to be async for the signal to be bit perfect? I thought that we only speak about bit perfect when the signal leaves computer (WASAPI, Kernel Streaming and other output methods).
bitperfect is just concerned with the signal, while asynch is concerned with the timing of it. as far as i understand it, one isn't required for the other. they are just two halves of a whole.
i'm assuming the main goal of outputting a bitperfect signal from the computer is so that the DAC will receive the complete, original signal (all the bits). whether the converter allows the pass through of a bitperfect stream, or alters it along the way, is the question i'm curious about.
Well then I suppose you're missing everyone's opinion that the digital interface is an improvement over most other spdif converters and is not causing people to "experience any loss or degradation of the signal in the process." I provided the HDCD and DTS examples because those are things that won't work with the DI because it isn't "bit perfect."
and i suppose you're missing the point of what "bitperfect" means. it has nothing to do with "everyone's opinion" about "improvements." it's an objective, measurable, technical feature.
When I sent email to Kingwa in Jan, he said the only device with USB from AGD using asynchronous process is DI. None of the DAC with USB has async.
hopefully that clears things up, though it would be nice if he chimed in here to confirm and/or explain.
