Rage038
- Oct 17, 2013
That's probably the best thing to do. Hopefully they provide you with a 10-15 cm cable.
Been following the Fiio E18 but came across this and the form factor is so much more friendly for my train commute. That price though! I guess that apple license is pretty expensive...
If they require a proprietary cable I would expect more choice than only a 15cm lighting and 1m USB cable at least as an available accessory; but really more should be included in the package. Personally I would not purchase this AK10 without also a 1m lighting cable, allowing me to put the iDevice further away and have the AK10 in a convenient location. 15cm seems a bit long for making an iDevice/AK10 "sandwich", but too short for having the iDevice in the inner jacket pocket and the AK10 on the hip... At ~300$ this should be solved.
Placed my order, I hope it pairs nicely with ipod nano. Its price and versatility makes it a good relatively cheap for on the go music listening in cases where you dont want to take anything expensive.
Hopefully it pays off and hopefully some genious figures out how to pair it with ipod classic.
I know onkyo has an app that will let you send HD audio out but I have no way to check if it will work.
I guess I'll find out I hope it does. What makes it appleaing for me is that it is not just an Idevice dac alone, that is a big plus and it is the smallest device of its kind.Hi, are you sure it works with the iPod nano because it's not listed as a compatible device on their website. Astellnkern.com
That would be great to know!
I am confused since there are many apps claiming 24/192 playback via apple camera connection kit...
But according to Astell & Kern the AK10 is via iPhone only able to get 16/48...
I am wondering if all these apps claiming 24/192 can deal with iDevice Dac/Amps without the camera connection kits...
By the way I found a store claiming to have the AK10 in stock...
http://www.hk-68.com/newrecordsproduct/headphone-earphones/headphone-amplifier/astell-kern-ak10.html
