?? Few posts back you said "ak240 + tur06 using lineout (max volume) they are too loud even on very low volume on the tur06". So, can you clarify if the "line-out" of the AK240 is appropriate or not (too loud) for the sensibility of the TUR-06 ?
on my tur06, shikada was made it to match the impedance of my first gen ak100.
he mention this on his email:
"About #004,
I tried to use the attenuator of the current type.
The sound is better than voltage type.
However, it is not will be a mute.
(up to -50~-70dB)"
"I made a higher gain. If you want less quietly, Put a resistance of 10Ω to the output terminal as connected in series."
i am not sure whether this is the case or not. perhaps GG can explain a bit more,
ak240 has more power output than the ak100. on my last setup i was using the pandora hope vi which has only 8 ohm impedance. and yes on very low volume it is too loud to my ears. and causing the buzzing sound at the low volume as well (set line out / max volume on the ak240).
But when pair the ak240 + tur06 + higher impedance headphone at least 30 ohm (on my grado) or above the sound are more controlled and less noise background.
ak240 + tur06 can drive my beyer880 250 ohm very beautifully and loud at maximum volume on the tur06. I think it will be best to pair them with 32 to 300 ohm headphones, less then that it is better to drive the headphones direct to ak240.
so these are my best setup so far:
ak240 + tur06 + ms1i mod.
I fell in love with grados. they never heard so good before. they sound like a home speaker set up. not too much surgical details present or super airy high, they just simply play music beautifully to my ears.
So next i will be in search of higher end grados like gs1000 or rs-1. or maybe trying out the lcd xc or x.
note: you need a good interconnect maybe some pure occ quality wire to make the best of the combo.
