just a short status update:
today i ordered some additional parts needed for my high-end tu-05 mod:
WIMA DC-Link capacitors for the anode voltage stabilization:
2x WIMA MKP4 80µF - 57x45x55mm (sample picture below):
and 2x WIMA MKP6 550µF - diameter 85mm, length 132mm (sample picture below):
These capacitors are NOT eletrolyte capacitors but REAL MKP foil capacitors like the Mundorf TubeCaps, big size, very expensive but MUCH better than electrolyte capacitors, very low internal resistance in the range of 1,7 to 3,5 mOhm (MilliOhm), the capacitance of the 550µF ones is big enough even for 3 or 4 DL92 tubes in parallel for each output channel and can provide a current of up to 30 Ampere eachl!
also i ordered some LT1170HV dc/dc step transformer ICs,
- they are compatible to the ICs used in the original internal power supply board, but designed for HV high voltage up to 75 volt, designing an internal anode voltage board is possible based on the original design, but increasing the anode voltage to 75 volt will result in a much higher output power of the DL92 tubes, with four tubes in parallel i expect an output power of at least 1 watt per channel so the highend build will be able to drive high efficient loudspeakers (you may remember my SABA Greencones i bought some time ago).
and i ordered two Sowter Pro Audio 3575 Ohno Continuous Casting (OCC) LCOFC General Purpose 10K:10K Input Bridging Transfomers Model C:
Used as Input transformers my high-end mod will be real double mono from input to output providing balanced and unbalanced inputs!
to get rid of any hiss/noise/RF in the filament voltages i made a design for a filament voltage power supply module with one Li-Ion battery for each tube without any dc/dc step down converter instead using an LM317 as constant current source and two diodes for the stabilization of the voltage (2x 0.7v = 1,4 volt), so waisting some energy, but adjustable exactly to the current the tubes need (25mA, 50mA, 100mA) which should be the best way to provide the filament voltage limiting voltage AND current exactly according to the tubes spec. also this module has a slow power up / slow power down function, protecting the tubes even more!
i have decided to use multicolor LEDs (red, green, red+green=orange/yellow) in the tube sockets (green = filament voltage on, RED = Anode voltage on, yellow = tube ready all voltages on).
So what's missing to start?
- for a full battery driven version with higher anode voltage i need new li-ion balancer BMS boards, the ones i bought are for 16 li-ion batteries each, for the higher anode voltage i need BMS boards for at least 20 li-ion batteries
- a TKD CP2500 HighEnd Potentiometer
(50 KOhm log. typ +/- 0,1dB; max +/- 0,3dB)
- a meridian director to be integrated into the amp (the HRT MicroStreamer would be a real sound quality limiting factor)
- about 50 Li-Ion batteries and battery holders
btw, today i sent my colorfly c4 to the HIWIWERKSTATT hoer-wege to be modified with high quality components.
