good to hear!
i also sometimes read through my postings of my impressions of different tube combos and listen to them, all of them have strong or not so strong points, but for me and my diy grado style headphone the rft df97 - philco 1s4 is a match made in heaven.
i have to say that while for the not so experienced ones if it comes to electronics the standard tubes are a natural choice as ianmedium does (and they are mentioned as standard tubes in my compatibility list), but that should not result in inducing fear to use tubes that are compatible and CAN be used without any risk.
it is just a matter of fact and electronic design that for example the 1s4 is not an 'incorrect' tube but after cutting pin 1 or modifying the amp with a switch for pin 1 is fully compatible, even if shikada-san had only the df91 and dl92 tubes as primary tubes in mind when designing his amp. the compatibility is independent.
a pin compatible tube (dl95) that works, i.e. you can listen to music, but due to too different parameters for bias, grid and anode voltage will distort has not found its way to the tube compatibility list.
each tube type in the tube compatibility list was at least tested for 8 hours, so even a wrong bias and so constant current flow through the outout transformers did not happen (could result in overheating up to damaging them).
so as i wrote as intro to my twin output mod one should know what he is doing, but there is no risk to cut pin 1 of a 1s4 tube or connecting pin 4 and 5 of a df97 tube or using a df96.
