- Oct 14, 2013
I am surprised that with this outbreak and Ibasso stuff still arrive that quick! That is insane ! Ibasso is working the “magic”!
Theoretically speaking...If Ibasso ever to make such mainbody LoLSo am I correct in saying the modified main body of the dx220 done by Ibasso and the modified amp 8 is called Dx220EX-FE and a modified amp8 by ibasso is called amp8ex- fe ?
The Amp8EX alone can not squeeze out enough Bass and trebles Details and extensions as much as the main body EX upgraded. The DX220 was designed with modular design, and so the Main body is the Sources and the Amp8 is an amp. Just like any high-end system, if your sources is not up to par, then the amp can only do as much. But needless to say, if you have the Main body Dx220EX, then the experiences of the whole combination is going to be Elevated into another notch yet again!. To me, the Dx220EX is very important, a must
Yeah, but I have doubts that it would ever come to surfaces. Anyways, we can keep dreaming LOLThe term main body I actually got from you
Oh I misunderstood, I thought they had upgraded both. Thank you for explaining.Yeah, but I have doubts that it would ever come to surfaces. Anyways, we can keep dreaming LOL
Has anybody compared the DX228EX-FE with Fiio M15. I'm considering an upgrade from the Dx208 but unsure which. Any thoughts would be helpful.
The only DAP I'd think about replacing the DX220 with right now is the new KANN Cube, but then I look at its price and footprint... all that for a a few more volts and the 9038PROs over the DX's 9028PROs and I'm not quite sure it's worth it. Also not sure if the Kann andoird supports UAPP, which has turned my DX220 into a streaming powerhouse.I’m thinking about selling my DX220, which means I’d be selling my AMP8EX Fan Edition. But then I read posts like this, listen, and I reconsider. Damn. It sounds so good.
Did you try Headphoniaks? https://headphoniaks.com/tienda/ibasso-dx220-max/Since the new DX220MAX has now run out of its 999 initial units (yes, I know, it's truly a sad news !),
and I'm sure of it because I have not found any DX220MAX in current stock in the whole Europe, by authorized dealers, including my own country (France),
and this happened in less than 2 months after the launch, (999 units is a too lower number considering to have to contentate all the possibly so much iBasso sounds lovers around the world !).
Do you know if iBasso will soon produce some new Amp8EX-FE units for the DX220 ?
If yes, does someone already knows when the 3rd batch will arrive ?
Thanks a lot for your help !
