drewd
Banned
- Apr 26, 2004
24 Volts. The heaters in the tubes are designed for a 12 volt system and since they are wired in parallel, that gives them 12 volts each. The bias voltage should be set to 12V, but you can experiment a bit with that voltage. Your ear is really your best guide - and you may not hear any difference over a fairly broad range of voltages.
Probably not. My STEPS is in an aluminum Hammond case and it sits directly under my Millett in another aluminum Hammond case. I hear no hum, even at full volume. I use it at work, where I'm surrounded by fluorescent lights, computers and electronic test equipment. Oddly enough, the only noise that I ever hear is from my cell phone, but that appears to be coupled through the headphone cable.
If you get hum from the power supply, then yes, it does need to be steel, or some other material that interacts with magnetic fields (mu metal, nickel, etc.)
I happen to like the 12FK6 best of all of the tubes that work in the amp, but you might have a different opinion. Since the tubes are pretty inexpensive, try a couple of different sets. I'd recommend starting with the 12AE6A and 12FK6.
The amplifier does not use a feedback loop for gain. The gain is set by the constant current diode on the anode. You may want to reduce or even eliminate the 22.1 ohm output resistor. It was originally placed to protect the buffers from a direct short, but the BUF634s have internal protection, so it's not strictly required. The amp has plenty of gain for your Sennheisers.
Good luck!
-Drew
Originally Posted by pabbi1 Several build curiosities: a) What is the optimal (in your most humble opinion) voltage setting (using a STEPS) for the 12ae6a and the 12fk6 respectively? |
b) I am using a wood front panel on a PARS metal case - is steel shielding (an easy option for me) likely to be needed? |
c) The PARS metal case has an aluminum divider - does that need to be steel (an easy option) to shield the Millett board from the STEPS? |
d) Which tube set is likely better for Senns (HD600 or HD650)? |
e) Do I need to adjust any resistor values to boost the gain for Senns (600/650)? |
Good luck!
-Drew
