aeroes
- Oct 20, 2004
Im about to finish my order but I have a question.
Can I use 25v for C7L/R position?
Originally Posted by aeroes Can I use 25v for C7L/R position? |
Originally Posted by drewd Yep! |
Originally Posted by drewd When I have my electrial engineering hat on, I would say that any caps in the amplifier should have a voltage rating of at least twice the voltage that they may be subjected to. In the case of C7L/R, the maximum voltage is V+ or 24V. That assumes a couple of things:
So, as an EE, I would use a 50V cap on the output. From a pragmatic point of view, if V+ is present on the output, you'll know that something is wrong right away. You most certainly will not be listening to anything. A 25V cap will block the DC at V+. And it's not going to explode or anything like that - in fact, it's not going to fail even if the voltage drifts up above 25V because you're not going to be listening to anything - you'll be turning it off because it sounds terrible! So, 25V is fine. There are a couple of reasons that I specified 50V caps when I made up the BOM on the website. Pete's original amplifier used them. The original amp that I built used them. And I was looking at the caps with an engineer's eye for design. Since there are also 5mm pin spacings on the board, lower voltage caps can be substituted. Also, please bear in mind that 100uF is not a magic value. I get the impression that Pete must have had a bunch of them on hand, so that's what he used. There's nothing wrong with using larger caps. They're bypassed with low ESR film caps, so there is no impedance issue. I hope that I haven't made things more confusing. The bottom line is that the power caps will see 24V all the time and the signal caps will see about half of that all the time. The specific value of the caps is not critical - well, C7L/R depends on your headphones, but, practically speaking, it's not really critical. -Drew |
Originally Posted by Finch&Music 1. With the above pre-requisites of a 24 v supply and a max bias at 24 V: could there be not any problem presented to your (pricey!) headphones when elco's of 25 v are executed? (Forgive me my little electronic insights, I am only looking for some insurance against stupid implementations with risk of damaging my headphones! |
2. In general your EE approach gives me more confidence feelings than looking for the lowest possible voltages or values for a little less cents. |
3. By the way:what will be the maximum practical bias volt adjustment to expect with the different tube types that will be practised? Is'nt that maximum also to determine the max supply voltage and the practical voltage of the electrolytic's? |
4. I am planning a supply-set at 30V (STEPS based on talema 25va/2*15v; see earlier posts). In that case I assume that after regulation at 30V a 35V range (minimum) on all caps is mandatory, even in the position of C7. |
5. That strategy gives me - as far as I can imagine - the most flexibility in bias adjustment. Or is that bias-aspect fully separate of the (max) supply voltage in all other positions? |
6. In regard to the question of leadspace (and the added flexibility) I want to remark that - if funds gives you the space - do not go for the lowest level possible. I think the amp will benefit from some headroom in the supply and in the (quality) capacities on board. Than I am speaking of a balance between quantity, quality and (local) price. |
drewd said:Thanks for your very explicite answers! As always it gives insight and help in choosing components and making dicisions on configurations.
On the topic of different tubes :
I have seen that a 12AE6A has another (= greater) amplificationfactor than f.e. a 12FK6. Is that factor of any significance in the sonical results?
Some other specs are also a little different. Are they of any importance? Or are that kind of different tube specs rulled out by the biassettings and/or volumesettings?
I want to add another topic to all the members of this thread:
I am in the process to choose between tube-brands. I have already chosen for a pair of each tubetype mentioned on the thread or componentlist. So I have already one pair of 12AE6E, 12FK6 and 12FM6 (all Sylvania) on my orderlist.
Because I want to do some tuberolling in the future I want to choose between some brands. I have seen on the internet some possibilities. Is there anyone under the threadmembers that can already give me some advise on brands to choose. For example on the basis of expirience with tuberolling on the original Millet amp or maybe some members has already expierience with the prototypes of the revised board.
I ask this on this moment because I have to order the possible different brands for additional tubes preferably in one order, because of all the added expenses of shipping etc to Europe.
Greetings,
Pieter Vink
Originally Posted by Finch&Music I have seen that a 12AE6A has another (= greater) amplificationfactor than f.e. a 12FK6. Is that factor of any significance in the sonical results? |
Originally Posted by Finch&Music I am in the process to choose between tube-brands. I have already chosen for a pair of each tubetype mentioned on the thread or componentlist. So I have already one pair of 12AE6E, 12FK6 and 12FM6 (all Sylvania) on my orderlist. |
Originally Posted by kilkil It looks like C9 and C10 should be electrolytic caps on the excel BOM |
