Well worth a try, both the white and red are inexpensive compared to the well known competition. Also to my ears both felt very sonically balanced. To my ears the white is more musical and red more resolving.
ah thank you, i might try the red or black ones at some point but from what i heared the white one is probably hard to beat price/performance wise
the difference seems to be :
black and white are basicly like the white one but
1. instead of quartz only, red and black has quartz + ghraphene
2. red one has a additional occ silver wire wrapped around the silver alloy fuse wire (which seems to be identical as in the white one)
3. black one has instead of occ silver, a occ copper wire wrapped around the silver alloy fuse wire
probably a taste thing if you like the occ silver or copper better, probably will try red in the future
i need soon around 7 fuses for my DIY dac build, i think the white ones are a cheap no-brainer if you believe in fuse sound but dont wanna spend much to get the build on probably some kind of solid "mid-level" but im still very hesitant on buying expensive fuses, yes pretty sure they make a difference but at some point i rather look into other imo more important upgrades
But my reaction to the red fuse was it made a much bigger difference than the ACME vs a glass fuse.
its really great that these sort of chinese manufactors get a foot in the door with these prices, imo its not about getting the best fuse here but to get a pretty good one for basicly not much more than regular fuses
tho what i hate in the chinese market are all these fakes or false claims, its hard to find legit offers imo, with most fake stuff you are never sure if its pure copper or brass etc...
