lini
Thought the last line in Citizen Kane was nosebud.
Neruda: Yeah, that leather headband is really nice.
Tim D: Oh, maybe I should mention, that harsh treble is what bothers me most - and the K401 seemed definitely harsher to me than the K501. I didn't really compare the bass except from a short listen to the sound in genereal. After that I concentrated on mid-range and treble, where the K501 seemed superior. But from how I look at the graphs I would prefer the K501 for higher impedant outputs, whereas the K401 should work better for output impedancies below 240 Ohm. I now wish I had compared them for bass extension, too, but I didn't. So it could well be that the K401 provides a little more punch - but when punch is needed the beyerdynamic DT531 is my best choice at the moment, anyway. Far comfier than the SR80, which only seems to be nice with low impedant (below 60 Ohm, I'd think) outputs, anyway - otherwise it will sound thin and very harsh, it almost brings the comfort of the K501, but provides some more bass extension and much more impact. Soundstage-wise the DT531 is also not a bad contender at all. And I also like the sound of the Philips HP890 more than the K501. The Philips provides a very good balance with very deep bass extension, nice impact, and a very wide flat bandwith from bass up to the lower highs - only the medium to upper highs seem to be a bit harsh on higher impedent outputs. Nevertheless the HP890 is a bit huge and bulky on my head and the clamping fouce could be a little higher so that it wouldn't hang over my ears at all, which it does a bit...
Greetings from Munich!
Manfred / lini
Manfred / lini
