heh he.... thanks for the compliment.
post some pics man.
using non-star quad does make things so much easier though. soldering those Cardas Rhodium Milled spades are a major pain!... and i bought the kind with two holes, thinking it would be cooler since i'm using star quad. welp... those things are so big, that when heated up to the correct temperature, they burn through the socks that i use as padding on my clamp. they hold the heat too much due to their mass... after i remove my soldering pen, the solder is still liquid for like 30 seconds! would have been lots easier to deal with if i only had to use one hole.
but the final product looks pretty cool. i could only imagine how they sound... haven't had a chance to use them yet, had to ship them out immediately...
how did you like them anyway, besides just their aesthetic value?--i mean, you hear a difference?
heh he... you probably noticed that my spade terminated product was a bit better constructed compared to my 1/4" plug version (less heatshrink, cleaner design, better colors). electrically both are pretty close in performance, but i think the spade version looks a lot more impressive. got it down the second time!--practice makes perfect. i've soldered more than 500 plugs before for my studio... but this headphone cable thing is different--fun though.
