bahamot
- Sep 17, 2005
I think my M is busted. Stuck at "Calyx M" logo, then nothing... I even can't get it entered firmware update mode.
I think my M is busted. Stucked at "Calyx M" logo, then nothing... I even can't get it entered firmware update mode.
that happens to me few time, it is that if you press the off button for too long it goes to a different sequence. I honestly have no idea how many second i need to press in order to enter the main menu, it is a lottery!
Does the logo stuck or disappeared right away? mine disappeared right away. then blank ...maybe gonna RMA it.
Edit:
Jaben agent said it might because of the battery was too low. Let's see how later ...
could you please provide link for the same.yea it does, it is a cycle thing, calyx M really need to provide a user guide, I am almost certain pressing the off button down for too long will tell to do wait for other buttons to be pressed and do a certain thing. Infact they are aware of it, they have provided a guide on how to charge your device if you devices does what your one does.
The pause/play button tend to stop working when screen is off, in order to reactive it screen needs to be turned on.
If the music is playing, the Play/Pause button will work. The screen does not need to be on.
If you stop playing music, the M quickly enters a Sleep state. You need to press the Power button followed a second later by the Play button to restart the music.
I'm a UI fanatic so I learn this stuff inside out. And yes, they should provide a manual. No doubt they will at some point. We are kind of beta users at this stage, pre-1.00.
I dunno if I understood the original passage correctly cos it's quite complicated,
but Here's my direct translation;
When the voltage gets lower than 3.1volts,(due to battery gets low)malfunction of charging sequance mode has been reported.
We're on this, to fix the problem.
Anybody who experienced these problems before your firm up, charge your device by following method.
1.In case of CalymM logo doesn't appear after pressing the power button for 3~4 seconds,
Press the power button longer(more like 10 secounds, if CalyxM logo appears before 10 seconds, press the button for a while again)
Take off your finger from the power button,
Press the Fast Farward button and while you press the button, connect the charger,
Charge your device for about 60minutes by this method, Press the power button till CalyxM logo dissapears,
and press the power button again, the device will start booting and will start charging.
2.In case of pressing the power button for 3 to 4 seconds, CalyxM logo appears and then nothing comes out on the screen.
Press the power button for about 10 seconds(if the CalyxM logo appears before 10 seconds, press the power button for long once again.)
and take off your finger from the button.
Press Fast Forward(underneath the power button)for 3~4 seconds, CalyxM logo will appear.
If you see the logo, take off your finger.
Charge about 30 minutes like this, then Press the power button till the logo dissapears,
then press the power button again will boot the device leading to the chage mode.
Quite complicated...
Seems like D&A is on work to skip this complicated issue...
not about folder browsing this time...
