analogsurviver
- Jul 2, 2012
[redacted] Oh nm, it's you analog
Even if I nm (redacted), RRod please try to go trough the entire post and, if required, read in between the lines
Even if I nm (redacted), RRod please try to go trough the entire post and, if required, read in between the lines.
More I didn't want to rehash things when I know well your position. I agree with you on the DG sound, btw, though there's too much good material to avoid.
So I found out dbpoweramp needs to be purchased to convert flac to mp3 after trial expires so I needed more time to get the CDs out of storage and ripped to mp3 via EAC.
Then this came in today, Steven Wilson's latest album HAND. CANNOT. ERASE. which includes a download in 16/44 both FLAC and MP3!
And so after I get a pattern down for a proper abx technique i was able to get an accurate hearing of wether a/b=x or if a/b=y. I will admit it wasn't easy and took several loops of the same 5-15sec segments but here's my result with my secondary chain of: Foobar ABX <cheap usb cable> Vlink 24/96 <spdif rca cable> Audio-gd NFB11 >> Fidue A83 triple hybrid iem. My He560 at home is a better rig and I'd expect the same results.
A bit blurry so 9/10 with 1.1% chance of guessing. ABX is not half as fun as actually listening to albums. Totally a snooze fest that requires concentration but yes I'll take my FLAC lossless anytime over lossy, even on my less than great Samsung Galaxy S3. YMMV
Tags: @kraken2109 @bigshot @sonitus mirus @Music Alchemist @RRod @Stillhart @AxelCloris @Ivabign
So you weren't able to convert the file and ensure that it was encoded properly, you simply downloaded 2 separate files? You don't even have the necessary tools to convert a file or rip a CD to a properly encoded lossy format? Were the 2 files you tested even volume matched? Were you allowing the spectrogram visualizer to run during the testing?
If it was me, I would certainly want to investigate a bit more thoroughly. I'm able to identify a difference between the Tidal music's FLAC and AAC 320 test every time 15/15 in under 3 minutes, but it was discovered that there was a subtle EQ being applied to one of the formats that seemed out of place and did not occur when I encoded the same music to the same formats with EAC or dBPoweramp. Maybe the files are different due to an inferior encoding process?
Unless your only goal is to show others that you can hear a difference, there are a lot of issues to address with the methodology of your test. If you really want to know for yourself if you can hear a difference, there is some more research required to be more certain.
There's more to these tests than the final sample ratio, but getting that all worked out on a forum is a messy business that usually pisses someone off ^_^
Lol more hoops huh? I'll re-rip a CD in mp3 and recheck. I don't know how to run the spectogram during an abx so i wouldn't know. However a flac v mp3 abx from the same cd should make this irrelevant.
But I'm guessing the mp3 and flac rip from Kscope is the same master, I can email them to verify.
See what I mean with my quote above
I like DSD particularly for the fact that it can not be mangled with PCM>DSP every time some computer geek would like to sell yet another DSP software of one kind or another.
IF you personally can fathom the thought of making a recording and playing it back without any computer (except the recorder) within miles, then you might, just perhaps might start hearing the advantages of DSD over PCM. With live mike feed as a reference. And not remasters of masters done by third and fourth party, at and during which you most definitely were never present.
If I were to simply enjoy music I think mp3 would be more than enough, however I want all the data audible or not in my files.
Sorry, but this seems like willful ignorance. I don't know of a single headphone or loudspeaker (even high end) which would not benefit from digital EQ. And yes, that EQ will bring you closer to the live feed you mentioned. That is just one of several reasons why I am only interested in a computer-based digital audio system.
As for DSD releases, they are mostly captured and mixed using PCM anyway, and the final result is transcoded to DSD, a process which just introduces distortion and noise (not that it will be audible in the real world though). Still, it is always better to get the PCM release if there is a choice.
Sorry, if the headphone or speaker/room requires more than a decent analog parametric EQ, it should be optimized differently.
Originally Posted by analogsurviver /img/forum/go_quote.gif
Recording DSD and editing with the least invasive PCM tools only at and around the edit point yields approx 90% pure DSD that can be provided to the end user. That means those 90% are pure DSD that never was in any form of PCM. Provided musicians are really up to the task and allow minor errors in playing to be issued, that percentage can reach 100%.
It doesn't work that way - if you want to use more than a stereo pair of microphones you'll need to mix the channels and that requires PCM too. Same goes for anyone recording in more than one take.
But impractical for almost all modern recordings, so basically irrelevant. Post tools can be abused but they are also very useful and advantageous in the right hands. Somewhat similar to Photoshop and photography.Originally Posted by analogsurviver /img/forum/go_quote.gif
The inability to edit in pure DSD is to me an advantage;
Why should I use analogue EQ when digital is so much better?
At the end of the day, artists want to mix, and use multiple takes, so PCM will be necessary and DSD becomes irrelevant. DSD is difficult to use and offers no advantage, only disadvantages.
