2359glenn
Member of the Trade
- Aug 16, 2010
I should put my bare glass C3g tubes back in someday.
The HEXFRED adapters are not going to look as nice as the 6BY5s
Cary 300sei use hexfred rectifiers as a factory upgrade option.
Fixed your post
They really are better then any tube rectifier. People pay $1000 for a TAK 274B crazy when 2 HEXFRED diodes
cost $2. Cary is getting rid of the 5U4s to HEXFREDS as a upgrade and they are much
better then any 5U4 or 274 no voltage drop or sag in voltage when the amp draws more current.
I prefer tube rectifiers but cheep ones I am not nuts yet to spend $1K on a 5U4 that could be spent on good 300Bs.
I plan on finishing my EL3N amp this weekend then I have a OTL to build then I will contact you.
Stay updated on Moon Audio at their sponsor profile on Head-Fi.
Cool! Thanks Glenn.
Do you want tube 42EC4 or SS rectifiers.
Look like we need to show the community this, one of the reason I moved away from Woo is the rectifier cost, WA5 uses 2 5U4, so double the $1k+ for rectifiers if going for totl sound. Maybe @badas can order a hexfred from you for his wa22 to compare to the tak he got and post his impressions.
On tge 42ec4 vs ss, the only reason you're not able to make the ss adapters is the base right? Do you think we could sacrifice a set of 42ec4 and cut them open, carefully with maybe a copper pipe cutter, slowly grinding the glass down, then remove the internals and make space foe the hexfred diodes?
Tubes all the way, but at a sensible price.
With tube rectifiers you can change the sound with SS is a take it or leave it situation.
