I am also not convinced. This is what I was told by Brent Jesse:
"The 8526 indicates most likely the 26th week of 1985. The 813 may be 13th week of 1958"
I'm going to ask a few more tube sellers I know. I'll update the other thread if I find out anything. All I know for sure is that I have a TS 5998 and a WE421A that look exactly the same, and a WE421A that looks completely different.
I would agree that "8526" sure seems to indicate 1985. Interesting... I would never have guessed that this tube was still being manufactured at that time. But Cetron did purchase some part of Tung-Sol in the 1970's. And it is my understanding that power regulator tubes were among the last vacuum tubes to be replaced by suitable solid state devices. So it would seem that Cetron kept this part of the business going as long as there was adequate demand.
Regarding the two different WE421As.... In my experience, for reasons we can only guess, incorrectly labeled tubes are not all that uncommon. For example, we occasionally see the wrong tube number, the wrong brand and even the wrong country of origin. And thus, my rule is the label should never to be trusted. It is always necessary to closely examine the construction to determine if the label is accurate.
I continue to believe that all WE421A have bottom getters. And thus, in my opinion, if the tube has top getters, it is a 5998, and not a WE421A. That said, not all 5998 have top getters. Once in awhile we see a 5998 with bottom getters. My conjecture is that these 5998 with bottom getters are simply WE421A that did not test up to spec when measured in the factory. Even though they failed to meet WE421A specifications, they still met or exceeded 5998 specifications, and rather than throw them away, they were distributed and sold as 5998.
So it appears that you have a 5998 that was labeled incorrectly as a WE421A. The construction - top getters, and your own listening tests would seem to substantiate this conclusion.
My advice, when looking to purchase WE421A, if there are top getters, let someone else buy them.
And I suggest that it might also be worthwhile to keep an eye out for 5998 with bottom getters. If my conjecture is correct, even though these tubes didn't test good enough to be labeled as WE421A, they just might still sound like WE421A.
But again, this is just my attempt to make sense of what we see.... and I could well be wrong....
Cheers
