Ike1985
- Oct 22, 2014
A few posts ago I was arguing with @Brooko over whether the UEBJ veils the sound. Now I know why that was the case with me. My UEBJ is not purely resistive. Today I got 2 new impedence adapters : 20ohm and 75ohm. The sound out of the 20ohm adapter and UEBJ is siginificantly different. I can't hear the veil out of the adapter but I can hear out of the UEBJ. As a reference, My comfortable volume is set at 55 with the adapter and 70 with the UEBJ. If both were purely 20ohm, they should have required the same power.
Now maybe the UEBJ has an impedence around 50-60ohm which can explain the veiling as then maybe my source does not have enough power to drive them in Normal mode.
With the 75ohm adapter, my source switches to high impedence mode. The UEBJ does not cause this switch so it's definitely below 75 ohm.
Now the next strange thing is if I connect 20 ohm then 75 ohm adapters then U12, the source switches to high impedence mode. However, when I connect UEBJ then 75 ohm adapter then U12, the device stays in normal mode.
I kindly request @Brooko to comment and perform tests if possible.
FWIW, my UEBJ could be broken.
Not sure about your results, many variables but UEBJ is indeed 20, this is verified by UE themselves.
