comabereni
- Aug 1, 2004
After a lot of research looking for quality bookshelf speakers in the $300 price range, I too ended up with Paradigm Atoms. I am driving them with the $30 Sonic Impact T-amp from my Chaintech AV710 soundcard. It's a very nice combo.
You can pick Atoms up used on Ebay for around $100 to $150, sometimes less depending on the version. You might get a deal on new if you find them in Canada since Paradigm is up there. Also, I read v.2 and v.3 Atoms are the same speakers, only upgraded in version number to match the rest of the Performance series.
Here are some reviews you ought to check out:
http://www.stereophile.com/loudspeakerreviews/664/
http://www.soundstage.com/revequip/paradigm_atom.htm
Wodgy has it about right--Atoms put out a nice, balanced, and very big sound for their size. You can use them without a sub and still really enjoy them. I'm tempted to say they sound "amazing", but I haven't heard the other speakers you referred to.
Atoms do lack just a bit of upper range detail and sparkle--it's there, but just not emphasized. Also, if you plan to use a sub, you might look for something just a little brighter sounding without as much bass extension since there does appear to be a modest hump in the mid-bass region. But I'm being very critical when I say these things as they really are a terrific sounding small speaker for an almost unbelievable price.
-coma
-coma
