Silt
- Dec 2, 2007
Hi,
I think I am about to throw my xonar away...
Some data:
Windows 7 Ultimate
Gigabyte mobo and xonar dx with the newest drivers
Senns Hd555 and Logitech x530
Well, I have my 555s connected to the front panel and it works almost(that will be later explained) well.
The speakers are connected with the standard wires to the back of xonar.
Unfortunately, when I carry out a speaker test so that each of them is to play separately, the rear speakers stay quiet. Front, center and woofer seems to be fine. I tried restarting, different settings and also messed with the win7 control panel but still no effect.
I actually haven't finished yet... The next thing is the the 'muting' right channel. After some hours of using the computer, right channel in both - headphones and speakers drops to 30-40% volume of the left channel.
I mean, both are still set for 100% of power. Only restart can fix it...
This happens even if I won't listen to any kind of sounds.
The solution of the magicians from Asus support center is that I should reinstall windows. God bless these ppl for solutions like those...
cheers
Some data:
Windows 7 Ultimate
cheers
