mb3k
- Apr 21, 2003
Is a 3-pin XLR AC power cable acceptable to make?
It will be implemented in my SOHA where I have to take 2x15VAC plus a center tap from the 2ndary of a transformer to the SOHA board (separate enclosures). Note that the trafo is rated max at 500mA.
I'm looking at some Neutrik XLR connectors but the datasheets don't say anything pertaining to this. All it says is that each contact are rated at currents much higher than what I will have going through it (ie. it says they're rated at 10A, 16A, etc.).
