Xbox One Stereo Adapter Power Output
Nov 18, 2014 at 2:53 PM Post #18 of 19
It came!! :)
I was having second thoughts about the E06 the other day, thinking I might just send it back and get the E11k instead. But the thought of having it not attached to the controller and in the way with extra wires was just annoying.
Anyways, the E06 arrived today, and after work I set it all up and boy does it sound amazing! So much clearer and louder then without it! The headphones really shine now and the EQ bass boost available is really incredible and adds some low end depth that the headphones really lacked when just connected to the weak output of the Xbox Stereo Adapter.
Anyways here are some pictures of my setup, it's so light that it doesn't affect the weight of the controller and I can't feel it there when holding the controller so it's perfect! I just need to wait for my 1.2m cable for my HD598's that goes to a 3.5mm jack instead of using the big 1/4" to 3.5mm converter..
Nov 18, 2014 at 10:35 PM Post #19 of 19
Not bad, glad it's working out for you.  :)
