ilikebands
- Feb 11, 2005
ok, so I came to this forum asking for advice for one of my earphones, in which the sound was muffled, quiet, and dying. someone said earwax could have clogged it and lo and behold, i disassembled the earphone to discover tons of wax clogging up the wire mesh. when i was cleaning it I accidently tore it out of the socket, so now I'm left with an exposed earpiece. now if any wax gets in that main inner peace that the mesh was protecting before, i know i'm screwed. is there any sort of covering i can try to fit over the open hole in my headphones now?
they sound brilliant though. the earwax was definately the problem. and before someone says to clean my ears, I do, everyday. I just have a ton of neverending earwax.
this is for the sharp md-33 model.
