Where to find replacement mesh screens for Samsung Buds?
Jun 14, 2022 at 3:28 AM Thread Starter Post #1 of 6
ScrofulousBinturong
Here
Someone gave me a pair of Samsung Buds that didn't work right. The sound was barely audible. I popped the earwax screens off and sure enough the buds are working great now.
I'd like to replace them. Where can I find sonically transparent replacements?
Thanks!
Jun 15, 2022 at 5:06 PM Post #2 of 6
The original ones I don't know, but you can find aftermarket ones on Amazon and AliExpress as long as you know the size in mm.
Jun 15, 2022 at 5:10 PM Post #4 of 6
Thanks. How do they attach?
I don't have any experience with those specific filters, but the ones I have used have a little sticky residue on the back and you put them in place with tweezers.
Jun 15, 2022 at 5:13 PM Post #5 of 6
Sounds easy enough.
Size wise, do you measure the outer diameter or the inner? The difference in the filters I've seen (4mm vs 4.2mm) are small enough where inner diam vs outer would make a difference.
Jun 15, 2022 at 5:14 PM Post #6 of 6
Sounds easy enough.
Should be inner diameter (ID)--if you can find the OG ones, even if they're not in stock, it might say what size they are in mm.
