What does coloured sound mean?
Mar 29, 2012 at 2:35 PM Post #3 of 28
Well basicly the opposite of neutral, the original signal has been twisted in a way it's not sounding as it was intended to, it can be anything like a boost or decrease in bass or mids or highs or usage of different filters/sound processings (Dolby Headphone, SRS to mention some examples) to the signal or even some devices (DACs/Amps) can color (or modify) the sound quite a bit from the original intended producer's signal.
Mar 30, 2012 at 4:36 AM Post #5 of 28
Unlike many, I like both neutral and "colored" sound. Depends on my mood. When I think of color, it's not "warm" or "cold", it's about texture and body, what I consider organic qualities. That's what I love about tube amps, you can potentially breathe life into a potentially bland recording, or take one that's very good and make it great. There are no rules with this. Sure I have good neutral SS gear for hearing a more pure form of a mix, and I do that a lot, but at the end of the day I'm plugging in to the big tubes and enjoying some ear candy.
Apr 6, 2012 at 7:40 AM Post #6 of 28
Distorted
To me distorted usually means a different thing, distorted sounds scratchy from amp clipping or the signal is being clipped for too much of a bump on the EQ for example. Colored may sound clean but doesn't sound like it was supposed to which doesn't have to be a bad thing either, it's more important if YOU like the colored sound or not than how it was supposed to sound like.
Apr 6, 2012 at 9:46 AM Post #7 of 28
I think the term distortion has a fairly concrete definition which leaves little room for subjective interpretation.  Distortion is an alteration of the original signal, colored sound fits this definition.
Apr 6, 2012 at 10:13 AM Post #8 of 28
So. If a driver was designed for a u-shaped frequency response, and faithfully plays it with absolute clarity and minimum harmonics, it's a distorted sound? Sounds iffy to me. To me distortion is just a bunch of unwanted thd and imd, while clipping is clipping.
Apr 8, 2012 at 8:23 PM Post #9 of 28
Yes, this is still distortion.
Technically, everything that alters the shape/sound of the original signal can be called distortion. This isnt always bad however; many (not all) people appreciate "tube-sound" (a pleasurable form of distortion), while most do not like audible clipping. Even EQing is a form of distortion.
So yes, coloured sound is distorted sound.
Apr 9, 2012 at 6:29 PM Post #10 of 28
I don't see it as distortion at all. If something plays a certain way natively due to its construction and/or form factor, then it's playing it faithfully without any distortion. We're not talking about tube coloration, but a speaker's native sound.
By your logic, digitally EQ'ing a DT990 to have a more linear frequency response is less distortion than playing the same DT990 without EQ.
Apr 10, 2012 at 3:41 PM Post #11 of 28
Same, I don't see colored same as distorted and I certainly haven't seen any set-in-stone rules for this being the rule either. I gladly would see some references for that if you think otherwise, a forum "glossary" doesn't count.
Distortion I see more like unwanted change/noise to to a signal which is bad in all circumstances while colored may even be wanted/positive in some cases such as "tube-sound" for some people. Amps could be adding more warmth or more brightness but I wouldn't classify that as distortion, then nearly all equipment would concidered "distorted" :P What ISN'T distorted in that case then? :)
Apr 10, 2012 at 4:42 PM Post #12 of 28
If you have headphones that emphasizes bass they are still distorting the original sound information, even if we (usually) like it. Motion blur in video games are also a form of distortion -- even if rarely spoken of as such.
Wikipedia has a fairly good article on distortion.
http://en.wikipedia.org/wiki/Distortion
(Also, noise and distortion are two separate phenomenons).
(I think amplifiers should be kept out of this discussion because it will leave to flame-war and locked thread, mark my words).
Apr 11, 2012 at 2:39 PM Post #14 of 28
Very.
They can be fun though.  Depends on your tastes.
Apr 12, 2012 at 4:05 AM Post #15 of 28
If your headphones favour bass/treble, its ' frequency distortion' as some comments say.
Tubes add 2nd/3rd/4th/Nth order harmonics, that is also 'harmonic distortion'.
All these represent colored sound.
