estreeter
- Jun 10, 2009
Hi All,
I'm not here to start OS wars - been there, got the t-shirt, and it goes nowhere - but I've had some very crappy results since buying my new Tosh laptop and opting for 64-bit Win 7. I had the Win 7 beta on my old netbook - no problems that I can recall - but I suspect things like my antivirus and possibly the Windows search engine are thrashing my hard drive at startup - not sure why that would manifest itself as noise (and I'm talking major static) into my USB DAC, but it does. The biggest problem is that its intermittent, and not necessarily restricted to startup.
I shrunk my partition and installed Linux Mint 11 - accessing exactly the same music and .flv files via the mounted NTFS partition from Linux, I have absolutely no problems with noise. Zero. Zip. Nada. If there is 'noise', its inaudible and that's just the way I like it.
I'm sure there is a fix in Win 7, and I was initially willing to kill processes until I could narrow it down to one (hopefully) single cause, but I'm at the stage now where I'd prefer to simply boot into Linux and listen to music. I'm also unwilling to disable my antivirus simply because it causes audio problems.
Passing this on in case others are currently tearing their hair out. Chances are its not your gear or your music files.
Cheers,
estreeter
Edit :
Configuration - Toshiba Satellite C665, Core i3, 4GB RAM, Windows Home Premium (64-bit), Foobar2K
Cheers,
estreeter
Edit :
