If audeze wants customers to experience their EQ, then they should force that upon customers like warwick do.
Is that really what you want?
That is pretty much always the case.What if a much less expensive system can sound just as good or better if you add EQ?
Internal vs external is the focus for me. Esentialy OEM vs aftermarket. I view it as comparing, say, a stage 2 chip in a car vs just getting the higher end model. It's certainly an interesting comparison, but viewing tuning (which is what I consider external eq to be) as required for a fair review cause the comparison just happens to be better tuned stock seems super wierd.DSP based PEQ is still done in software. The software runs on a DSP chip instead of a standard CPU, but the underlying algorithms are identical, only the implementation varies.
I'm haven't said people shouldn't be comparing eqed cans to eachother. I'm saying that viewing a comparison as unfair when it's stock for stock is wierd.I guess it depends what information you want to get out of the review. I certainly don't see how it is weird. Headphones are always part of a system regardless if the manufacturer sells it to you or you put it together. As I said, if your interest is only in buying and using an off-the-shelf system, then I see your point. I'm interested in buying the best possible system within a given budget and that means having each headphone setup to sound its best.
I'm reluctant to chime in, as it seems this thread is getting hijacked onto a tangent, but here's my $0.02 for posterity:
EQ built into the product, and which can't be defeated, is a different animal than user-applied EQ. It's part of the default tuning of the headphone (system), as delivered.
Electronic EQ (analog or digital) built into a product is not cheating, any more than are physical methods to shape frequency response in a headphone. Both are valid tools.
There's no single correct way to review a headphone. If a reviewer's method doesn't work for (or apply to) you, simply ignore or discount that review.
EOM.![]()
Well, you're making my point. Someone who habitually EQs all of their headphones is looking/hoping for a different review than someone who prefers to avoid EQ. Even if the reviewer EQs to what sounds best to them, there's no guarantee it'll be your optimal EQ profile. Trying to standardize this probably lands you in ASRville, where the vast majority of headphone reviews read as follows:I don't disagree with any of that. However, to me, the question should be what you as a reader want to get from a review. I want to read comparisons of different headphones and such comparisons are far more useful if both headphones are setup to sound their best. I'm not interested in reading a comparison of an X9000 amplified by a Topping EHA5 vs an SR-009 amplified by a T2. I mean, it might be an entertaining read, but it does not really give me useful information.
OK, but then the DCA headphones are given an "advantage" by AMTS tuning inserts, the HifiMan headphones are given an advantage by "stealth" magnet design, the ZMF planars are given an advantage by their proprietary damping system, etc.I think you are reading my posts as an attack on reviewers. It was not. I was trying to make the point that the Aperio is being given an advantage due to its built in EQ. I'll stop now.
Let's simply agree to disagree, and move on.
This seems to be where the disconnect between us is. I don't see how it's any different than physical tuning when it's how the unit arrives. I personaly see 0 reason to make a distinction between stock eq and stock damping tuningI don't see how it is similar to proprietary hardware that is physically part of the headphone and which can't be applied to any other headphone.
