Using Virtual Dynamics Genesis XLR interconnects as power cable wiring for apartment?
Jan 2, 2009 at 9:47 AM Thread Starter Post #1 of 2
Patrick82
Banned
I have 3 Genesis power cables daisy chained together using adapters. But with XLR cables no adapters are needed. How about using multiple of those for apartment wiring?
The difference between Genesis power cable and interconnect is that the power cable has an extra conductor for the ground. The XLR interconnect doesn't have a separate ground conductor, the grounding goes through the shield. I will not use the grounding of Genesis anyway, I will use RGC-24 Ground Conditioners which is better!
The pair of XLR interconnects is better for the money because you get two power cables for the price of one! Is it too good to be true?
Jan 2, 2009 at 11:56 AM Post #2 of 2
It probably is too good to be true!
But why not give it a go? I know you want to...
