atticusGoldman
Hey guys,
Kind of new to this stuff. Got a lot of headphones and a few DACs so I just got my first dedicated desktop amp (Garage 1217 Project Polaris) and I love it but I'm having a bad day lol. My Sabaj Da2 DAC just died after I discovered that the Polaris is indeed a quiet amp but I was having massive USB noise issues.
My original assumption that with such a powerful amp IEM use was probably a no go but it actually works fairly decently even without the attenuator cable I got with it. The real problem has actually been on the other end of the chain, the source XD.
I just got an Earstudio ES100 and it's been a revelation for me. I thought my amp was having noise issues with some of my more sensitive headphones but then I realized it sounded more like RMF noise, since my PC is in an open frame case, and sure enough problem solved by moving to another room. But then I realized just having the ES100 on Bluetooth fixed the problem even with the computer on and running right next to the amp which is also open frame.
So then I tried my other small usb DACs (dragonfly style dacs) and they all had noise as well. But plugging them into my phone's USB also eliminated the noise.
I have a pretty high end motherboard with isolated audio circuits and special clean DAC USB ports all of it noisy. Interestingly the line out from the motherboard also has the same exact noise when plugged directly into the Polaris. It's a static hiss with high frequency overtones and it changes frequencies correspondeing to the PC doing stuff so it's definitely the PC. But all the DACs in question and the line out on the PC are all super clean when driving headphones directly but the noise kills it when they are plugged into the amp.
I plan on getting an Enog 2 which uses optical and has its own power supply so that should solve the issue but I really would like to be able to use my ES100 over USB with my amp.
Anyone have any ideas as to what in the heck is going on and what the best solution would be other than ditching USB? I have heard of USB noise before but I also thought it was either just cheap low end PC components or way overblown as to the severity. Or do certain amplifiers hate USB sources?
