Hi, I'm new to this forum. I got lucky and found a used TF 10 vi set at a garage sale for $1.00. The sound fantastic. As I do not have a iphone and have no need for the mic and multi function button on the cable, can I replace the cable with one without those features? If so, any recommendations?
Ultimate Ears Triplefi 10 vi cable replacement
- Thread starter sschardi
Westone and others make a cheap replacement. Which you can get on amazon. Most 2 pin in the thicker size(.78 I think) tend to work.
Here is a decent cable if you want a over ear guide. https://www.amazon.com/Silver-Plate...8&sr=8-3-fkmr1&keywords=fiio+2+pin+cable&th=1
If you wish to keep the tf10 for a long time get a null audio cable from overseas. I don't recommend them with the ear sleeve as they are super light cables. This is what I use for my tf 10 and ciem. Lune: https://www.null-audio.com/collecti...ies-mkiii-premium-upgrade-cable-for-earphones
