Topping D30...no Output/Sound
Jul 24, 2019 at 9:04 AM Thread Starter Post #1 of 2
MamaLeone
Hi!
After problems with my Laptop i had to do everything new.
Laptop with Win10
After installing Win10 and the Original Topping drivers there is the Problem that there is no Sound.
In device manager is xmos listed and a message that the DAC is without problems.
In JRiver is xmos listed and its possible to start. There is no Message about Problems and JRiver is playing music.
But there is no Sound out of my speakers.
D30 get the Signal from PC/Laptop over USB and from D30 to Amp connected with chinch.
I‘changed the Input at Amp But there is still no Sound from speaker.
D30 is react from the Laptop-Signal off/on ( Blue light at the right side off/on)
Tested another chinch/usb-cable...Same Problem. Tested another DAC and everything works fine ( with the same cables)
Some ideas Whats the Problem?
Best regards
Heiko
