musaji
- Jan 27, 2015
Hi, I have been looking to complement my modded Little Dot i+ amp with a decent DAC. My current setup is hooked up through a marantz reciver's phones out, which sounds harsh and full of noise. The receiver is hooked up to my computer via a digital coaxial cable.
My budget is around $100-$130 and everything I have looked at, it seems like Shiit Modi is a fav. one. With version 2 now available ($110 shipped directly from their site), I am ready the pull the trigger. However, I just came across Topping D20 DAC which is a bit more versatile in-terms of number and types of inputs (optical, coaxial, USB) which is what I am looking for should I need to upgrade my audio rig. I also like that fact that I can roll opamp on it to enhance the sound further. I can find one as cheap as $120 online.
So what do you recommend? Topping D20 (versatile) or Modi V2 (simple and straight forward)? Any other options out there (I have seen some but they are either more expensive or the reviews are mixed)?
Thanks!
Thanks!
