headfinoob
- Jan 20, 2010
I have an Intel D945GSEJT motherboard with an Onkyo SE-200PCI LTD sound card.
I have a Fluke 77 Series II DMM. During playback I measure between 0.002 and 0.003Vrms AC on the 12V rail. When idle I measure 0.002Vrms on the 12V rail. The 5V rail measures 0.000Vrms at all times. When the computer is powered on with the hard disk drive (SSD going to be replacing the HDD soon) disconnected I measure 0.001Vrms on the 12V rail. The power supply rail itself measures 0.000Vrms at all times.
The Onkyo card to my knowledge uses an OSCON cap to filter noise from the PCI bus.
Does this AC measurement seem to be cause for alarm? Honestly, I can't seem to hear any noise from the system. Obviously, peak to peak ripple measurements may be much higher.
That brings me to my next point. I am using an ATX SMPS, the Corsair VX450W (with fan removed), with measures 50mV peak to peak ripple. The overall noise is rather low, but the 50mV comes from some rapid spikes and as I recall measured at full load. In any case, with the fan removed, and at a fraction of load, I suspect the power supply to be pretty clean.
Would a sinusoidal waveform be easier to attenuate than rapid spikes? I might switch to a power supply with smaller peak to peak ripple, (but it may have larger AC ripple) in order to help reduce noise. Also, would spikes of say 25mV - 50mV peak to peak magnitude cause premature failure of the passive filtering caps or are they more robust than that?
