I'm not trolling or anything. My intent is just to share an interesting video I found on reddit.com/r/audiophile
https://www.youtube.com/watch?v=-Bd99cADk70
The reason you need 24 bit for recording is because you are adjusting volume levels radically at times. For instance, almost all vocals are heavily compressed to make the words not get hard to hear under the music. If you apply compression to a 16 bit recording, the compressor is pulling up the noise floor as it boosts the consonants. It sounds like a sputtering steam pipe. But with 24 bit, the noise floor is so low, the compression is totally inaudible and the vocals are natural sounding and clear.
So now "stochastic resonance" is why people can hear the difference between 24 and 16 bit, even though when you ABX test them they can't?
That also gets to why I would prefer 24 bit for distribution at least for some music. I use digital room correction and a similar thing can happen (though it has surprised me how rarely) that correction will pull up something a bit audible that wasn't before. Though the correction itself may just be unmasking things. And to reiterate for some music. Very little commercial music is unmolested enough for this to matter.
You're probably right. Also, if your room correction is going so far that it's bumping into the noise floor of redbook, odds are it is being messed up in a bunch of ways. In my theater, I tried to adjust the room as close as I could get it to sounding good before I started making EQ corrections. It doesn't pay to do massive corrections to fix grossly off room acoustics. You just fix one thing and it causes another.
I'm not sure I follow, what does "stochastic resonance" have to do with mastering or manipulating data in higher bit depths? One involves the boosting of the signal frequencies by resonating them with noise, while the other aims to boost the signal in as clean a way as possible to reduce the presence of noise. The two concepts are at odds with each other.
It's the audible headroom for noise and distortion in hi resolution data that makes it beneficial for data manipulation (mixing/mastering) and simultaneously non-beneficial for final delivery. Nobody is saying you can hear 16bit vs 24bit differences on the original recorded file, but drag those files through a large signal boost or EQ shift and the 16bit version will pick up more noise and distortion. The final file delivery is a different thing. Nobody is changing the data during playback, so the headroom you get with high resolution has zero benefit at that point.
Oh, I was referring to the reddit thread; probably should have posted the link ^_^ :
http://www.reddit.com/r/audiophile/comments/2lfnzk/the_difference_between_24bit_16bit_audio_is/
The thing to remember though is that there are crossovers all over the place. Each multi driver speaker has a crossover, and there is a crossover to the LFE channel. Even if the sub was boosted a ton, the only noise would be below 80Hz. I don't think it's very likely that room correction would bring the redbook noise floor up. More likely the noise floor from a crummy amp, or distortion from overdriving would be the culprits of noise.
