That´s pretty little budget for a "musical" subwoofer ... you´ll end up with chunk most likely ... but there is a small very! musical sub from b&w for a little more ... have a look for the b&w asw608 ... used to have one till i switched to the new kef and the b&w is just great.
The cheapest sub that sounded decent to me was the Polk PSW111. Its the most musical budget sub out there (I've tried quite a few under 300$). If you step up to the HSU STF series for some more dough, its a definite improvement.
Uhm...the B&W is obviously the best, but it costs like 2-3 times the price of the Polk depending on where you buy it from. I have no idea about the Gemini. The question now becomes which one can you afford, not which one is the best, since they are all not quite the same price.
I'm a huge fan of Tannoy subs (I have the PS110B and love it). They might have something in your price range, and they are British, so they might be a good deal where you are.
