Mr_Junesequa
- Mar 4, 2007
hI,
oK so I bought some Dali Concept 8's, not exactly high end, but I managed to get them brand new at quite a bargain.
Im going to run my squeezebox to my dac magic, to an amp and then to the speakers (to begin with),
I was just thinking of getting a power amp with balanced input (even a PA amp) looking for amps is difficult, im on a set budget and the only amps with balanced input are cambrige and pa amps, I am low in my budget also, only being able to gork out 400US. but that doesnt worry me too much.
Im just not sure about impedance imbalance (will a good preamp fix this?) as well as whether there are certain amps which will work better with my concept 8's.. they are rated at 8 ohms..not sure what i really end up with ... between 6-8 id assume.
Can you guys lend me your skill?
Brands of low price amps with blanaced input
Impedance impblaance?
Pre amp or not?
concept 8's power rating is 165 watts
I appreciate all of your help!!
Pre amp or not?
