Sound proofing material suggestions?
Dec 15, 2003 at 11:18 PM Thread Starter Post #1 of 9
eyeteeth
The door of my listening room seems nearly totally transparent. Is there an effective material I can pick up at a hardware store to attach to the door? I am aware of products from echobusters.com, but thought there may be alternatives. Thanks
Dec 16, 2003 at 12:09 AM Post #2 of 9
Make sure you get sound proofing material not acoustic treatment material. I'd say the best thing is to start with a solid core door. The denser the door material the better (Lead filled would be best but it might also tear right off the hinges, a normal solid wood core should be fine). Then next best thing is to put limp dense mass on both sides of the door.
Something like:
http://www.auralex.com/sound_isolati..._sheetblok.asp
The stuff at echo busters looks only like stuff to treat reflections in the room, which won't do much to stop sound transmission through the door.
Also, make sure that no air can move through the top, bottom, or sides of the door. Stuffing something under the door would work for the bottom, try covering the tops and sides.
Now, I needed to stop sound going through a door so I used several layers of carpet and the most dense carpet padding glued together to hang over the front of the door. It also blocks the bottom, sides, and top. It works alright for the $25 I spent, but a solid core door with an air-tight seal would probably be much better. You can still have a conversation through the door, though you need to raise you voice a bit to do it.
Dec 16, 2003 at 12:18 AM Post #3 of 9
Daemoth, I am stuck with the door. As I will not be living at this address two years from now, the ideal temporary solution is a material I can lay up against the door when im listening to music. If there is a material stiff enough to stand on it's own? I am going to remember your advice for a semi-permanent recidence.
Dec 16, 2003 at 12:20 AM Post #4 of 9
You could use heavy duty door seals (the ones with the aluminum frame with rubber on the other end. , like the ones you use for your front entry door. That will help seal out sounds from the edges of the door.
You could also install a threshold and door sweep at the bottom of the door as well.
-Ed
Dec 17, 2003 at 3:47 AM Post #8 of 9
At the hardware store you can ask for a 4' X 8' X 1/2" thick sheet of sound board. This is what you would use to help soundproof walls in a home. You can also ask for building board which is the same thing, just painted white on one side. They are inexpensive and are the same thing as the smaller and thinner acoustical ceiling tiles. You can then trim and install the sheet over your door.
Dec 17, 2003 at 9:54 AM Post #9 of 9
COOL! That seems like exactly what I need.
