Jahn
Headphoneus Supremus Prolificus
- Jul 2, 2004
Slappa has made an ipod case for the 3G, and it arrived on my doorstep tonight!
The black psuedo velvety feel of the case is interesting - it seems to be tactile and stick to my fingers (good for grip) yet water bounces right off it.
the slappa logo is either plastic or very light metal - i guess we'll find out which after it gets scratched up. the thing that worries me is the plastic front - it's not a hard plastic like on the iVod, but rather a flimsy film plastic - this covers the screen and the scroll wheel but i'm afraid it will easily scratch, leaving the screen sorta of hard to read. but then again i'll have to wait until it gets into positions to be scratched first, so it's a wait and see. The plastic film is a bit raised from the wheel, so pressing down and rotating the wheel feels a bit odd, and i exert more pressure than i usually do to get contact consistently to make that wheel spin. It's no glide, that's for sure. the 4 buttons are no problem since they are exposed - i hope they don't get scratched up.
the clasp is the biggest problem. the magnetic button is pretty weak magnetically and just doesn't seem to snap easily and securely - thus the clasp takes a bit to stay down without popping back up, and dangles open at the slightest lift of my fingernail. the clasp is definitely metal, as is the gator clip in the back - that thing clamps like a beast, which is great - your ipod wont be falling off anytime soon. even if the clasp lets loose - that's because inside the case your ipod is snuggled into a basket and wont slip out easily even if the case swings open for any reason. the openings on top and bottom are plenty wide to let any headphone plug or line out or dock to access the ipod while it's still in the case - even a pocketdock.
This baby's got junk in the trunk. That's about 3 CD cases wide - an vaja case is about 1 CD case thinner, and my old skintight ipod skin is far thinner. But this case is still thin enough to fit into either my camera bag or my winter coat - it wont fit into a pants/shirt pocket, but during warmer weather that's what the belt clip is for anyhow.
I think that covers it - if you want to know anything else, let me know. For around $30, it's a serious competitor to the far more expensive vaja ivod case. It's not as svelte, but this Chunky Monkey could just be the ticket. BTW right now it's 15% off too, so check out our fine sponsor, Slappa!
