sig220
- Jan 10, 2004
Hello,
I just picked up a sharp 702 mini disc recorder for cheap at a garage sale.
Can you recommend a decent microphone for recording live music?
This doesn't need to be stealthy, but small enough to set on a small table and carry in a small camera case with the recorder.
Any suggestions?
Also, does anyone know where I might find a replacement battery for this unit?
Any other advice for recording with this unit?
The owners manual says "if you want to use a microphone, be sure it is a blug in power type microphone. when a plug in power type microphone is plugged in, the main unit will provide power for the microphone's operation. If a different type of microphone is plugged in, it may not operate properly, or it may cause the unit to malfunction".
How do I tell if a microphone is "plug in power type"?
The manual also mentions the ability to record in mono and thereby double the length of recording time available on one minidisc. This sounds like a good idea as I won't be seated near enough ot the stage to get much stereo separation. Does anyone know if recording in this mode would result in a lower sound quality recording?
Many thanks for your help.
Any suggestions?
