Hi all,
This is my first thread here as a member, but I've found my way to this forum many times in the past when Googling advice for audio equipment and it's been a fantastic resource, so I'm hoping someone might be able to help with a bit of a problem I've got.
First of all, a bit about me for context: I'm a trained musician, but not an audiophile – so I can appreciate good sound quality in a pair of headphones, but not necessarily be skilled enough to articulate what it is that makes them good. I mostly listen to classical music, so I tend to prefer audio devices that provide a flat frequency response.
Last year I bought a pair of Sennheiser RS220s that Richer Sounds here in the UK had left after they'd been discontinued. I needed wireless headphones for my study, and I'd read that these were about as close as one could get to neutral wired headphones but without the cable. As soon as I started listening to them though something didn't seem… right. There seemed to be a lack of clarity/brightness to them, with everything sounding a bit closed-in and muddy even though they're open-backed. I found that I was turning the volume up higher to try to get some passages of music to sound more lifelike. I assumed it was just a case of my ears needing to get used to them though so I continued to use them but was never entirely happy, and as a result didn't really use them that much.
Fast forward to today. I recently purchased a pair of HD558s to use with my digital piano, and I've spent this afternoon comparing them to my RS220s. The difference to my ears is really quite substantial. Comparing the same pieces of music has shown that the RS220s seem to be really deficient in mid-to-high frequencies. So for example, when listening to cellos/basses in some string music the RS220s will sound boomy and a bit mushy, whereas the HD558s will sound more natural and have more ‘texture’ to the sound – i.e. you hear the slightly course sandpaper-y bow-against-strings sound with the 558s whereas the 220s lack that and therefore sound more synthetic. Similarly with flute passages the 220s lack the breathy sounds that I would expect to hear and the 558s supply.
Also, when trying the 220s plugged in to my digital piano it's a similar story: notes in the bottom couple of octaves sound boomy without as much of the detailed piano string rumble I'd hope for, whilst keys around/above middle C are really timid and make the keys feel heavier as I have to put more effort in to the right hand to achieve an appropriate volume, but even then they sound tinny compared to the 558s.
I've found that a quick fix to this problem when listening to music on my computer is to use iTunes' ‘treble booster’ EQ preset; doing that gets me the texture I've described above that was so sorely lacking. The sound still isn't great (no doubt I'd need to adjust the EQ much more precisely), but it's a start. Oh and I've tried both analogue and optical connections, with no discernible difference.
So my question is: do I have faulty headphones, or have I simply made a bad choice? I thought the 220s were supposed to be for serious listening and would cope successfully with classical music, but mine don't seem to. I don't suppose anyone on this forum has both pairs of headphones and would be able to let me know if the big difference I'm hearing between them is expected?
Thanks in advance for any advice received (and sorry for such a long post).
