Seeking help from Lypertek Z3 2.0 owners [Tip size question]
Jan 24, 2024 at 12:52 PM Thread Starter Post #1 of 1
TooNice
My Lypertek Z3 2.0 died a while back while under warranty, and Amazon was awesomely refunded me for the purchase since they didn't have the stock to replace it. For that I did have to send back the damaged set, but I forgot to take the measurement of the tips. I can get the size of their foam tips since they sell them separately, but I am not sure if they are the same as the M sized silicone tips that I used and fitted perfectly.
The stock tips of the Soundcore Liberty 4 NC which I bought to replace my Z3 have a terrible fit to my ears, so I am looking into Spinfit, and would like to use the stock M sized silicone tips of the Lypertek as reference. I kind of suspect that it would be around 12mm since that is the dimension of their foam tips and it seems like 12mm is quite common for M size, but for piece of mind it would be great if someone could tell me what the size of the M size silicone tips on the Z3 are.
Thanks!
