Searching a hard shell case for B&O Beosound Level
Feb 1, 2022 at 8:45 AM Thread Starter Post #1 of 7
The1Signature
Germany
i just bought the beosound level.
since i travel a lot, i wanted to buy a hard shell case for the level. so i can easily put it into my car for transport.
i was not able to find anything on aliexpress.
any ideas or suggestions?
dimensions:
34,8 x 23 x 5,6 cm
Feb 1, 2022 at 8:31 PM Post #2 of 7
Feb 1, 2022 at 9:07 PM Post #3 of 7
Oct 7, 2023 at 2:16 PM Post #4 of 7
The closest thing i've found is a case made for "Akai MPC one" (DJ equipment).
This one is supposed to carry an MPC one + cable, internal dimensions are said to be : 37,3 x 27,6 x 5,7 cm, and you can adjust the inside length with an integrated separator ..
Look for "UDG creator MPC one akai case" : https://www.bax-shop.fr/housses-et-...94FnurxnB1NX5XTmaehoCnwQQAvD_BwE&gclsrc=aw.ds
I didn't test it myself but i will as soon as i get my level,
Hope that helps,
Oct 12, 2023 at 7:08 AM Post #5 of 7
@ColSaulTigh, @msing539, @N.Mendes
thank you so much. i forgot to mention that i bought a peli case. it is a little bit bulky though. but i want to try the akai mpc one like case, too.
thank you again.
Oct 12, 2023 at 7:40 AM Post #6 of 7
thank you again.
You're very welcome!
Being a filmmaker, i know how bulky pelican cases are..
But hold on on the Akai case, some people just released a case dedicated to the Level on ebay, i ordered one and will let you know if the quality is good..
Here is a link : https://www.ebay.fr/itm/39492446993...26&osub=-1~1&crd=20231011182057&segname=12061
There are plenty of sellers there,
Greetings!
Oct 12, 2023 at 7:43 AM Post #7 of 7
Greetings!
ah, ok this is new.
i don't like the fact that the places for cables etc. is in the same place as the device. no divider etc.
you can buy it also on aliexpress. Indeed, it is new.
