dweaver
- Dec 23, 2008
I posted this in the AD900 appreciation thread but think it needs a thread for it as I wouldn't mind other technical responses from people who have more experience modifying headphones as well.
OK fellow AD900 users, here is a question / observation / reversible mod I've tried.
I am still unhappy with the bass I getting from my new AD900's (burnin is improving the bass but I have been wondering if there was/is anything I can do to improve the bass.
I popped the pads off the phones and was looking at the drivers and was wondering if letting more air through the paper on the drivers would do the trick. Then I looked at the headphone cover and saw that it was covering up those parts of the phones the paper was located at. So I then looked at the pads wondering if I should do the phatpad mod to raise the pad off of the cup. It was during this investigation I noticed that the headphone pads had holes in the underside of it all around the pad.
It seemed to me the holes would reduce bass sound as the waves were absorbed and dissipated into the foam of the pad through the holes. So for a quick and easy reversible mod I took tape and covered up all of the holes in the pads. Then put them back on the phones.
The result of this mod seems to be more bass quantity/impact/punch. Has anyone else ever tried this mod?
My question for those who might understand sound technology better than I, would be is my assumption about bass being reduced by these holes correct, or would the holes be used to reduce treble and midrange?
Cover Removed from Headphone:
Partially flipped headphone cover showing the holes in the pleather:
Headphone cover completely flipped inside out:
Picture of Scotch Brand Gift Wrap Tape:
Picture of the size of tape strips I used:
Picture of partially taped AD700 headphone cover:
Like I said very easy to try modification
