red,green,blue,gold wires. HELP!
Dec 22, 2007 at 3:15 AM Thread Starter Post #1 of 3
thalin
alright, i have these really crappy headphones and i cut the cord in half so i could solder the jack side of the headphones to a RCA jack. i know how to do this but the colors of the wires are strange to me, i dont know what they do.
all i need to know is what color wires do what.
usually red=right, white=left, copper=ground
i have these painted wires though and i dont know which ones are which.
there is:
RED
GREEN
BLUE
COPPER
RED and BLUE are in the same cord.
GREEN and COPPER are in the other cord
please help
Dec 22, 2007 at 4:23 PM Post #2 of 3
if you have a multimeter just set it to a continuity check and take a look at the end with the plug still attached. You can check what color corresponds to ground, left and right. Then you'll know what goes where on your new plug
Dec 22, 2007 at 4:29 PM Post #3 of 3
I don't understand why you would solder RCA jacks (I assume you really meant to say plugs) on but...
If I had to guess, this would be the layout:
Right signal = Red
Right ground = Blue
Left signal = Green
Left ground = Copper
As suggested however, it would be best to test with a multimeter.
