Rackhour
- Nov 12, 2014
I'd like to get a new DAC/amp combo to replace my current Qudelix 5K at my workstation, simply for one reason: I want a visible indication of volume levels. This can come in the form of a display, or a physical volume knob with indicators.
The other conditions are as follows:
- I want the DAC to be USB-powered, without the need for a separate wall plug. I don't want to add to the already numerous mains plugs under my computer.
- The DAC will stay tethered to my laptop pretty much exclusively.
- I would like plugs for both balanced (either 2.5mm or 4.4mm are okay) and unbalanced jacks (3.5mm).
- I'd like something that's powerful enough for the HD6XX and the HE400SE.
- Bluetooth, MQA, internal battery, companion apps, EQ are optional. Plug and play away.
My budget is currently set to roughly $300 for now.
In my searches, I've come across the Cayin RU7, Qudelix T71 (both display, shows volume), FiiO Q11, "New" K3 (both notched dial), KA5 (display, don't know if it shows volume), among others.
Would you recommend any from this, or something totally different?
