R-Oak
- Jan 29, 2010
I recently purchased my first pair of decent headphones (hd650) and I would like to purchase a DAC+Amp to go whit them, but i had some really rooky question to ask first
from all the reading I have done this is what i have learned ( please correct me if i'm wrong ) or add details where you feel that something is lacking, i wont take it personal
1. most 100$+ DAC (schiit modi/ODAC/Audio-GD) can drive headphones correctly and speakers alike?
a. Is it possible using something like the schiit modi uber that has 2 set of output to be connected to a pair of active speakers and to be connected to a headphone amp at the same time (not needing to re-rewire) and to chose the output (if the headphones are plugged in or not)
b. what is low or hight gain and why is it important
2. Most headphones amp in this 100-300$ range can drive a lot of headphones and every single one of those amp has a different signature (compared to DAC, that shouldn’t do a big difference)
a. those amp can also be used as preamp for active speakers.
b. Preamps (when used whit speakers) are technicaly just volume control ?
A few question about imputs
3. Most people use optical to connect their console to a DAC
a. Would it also work whit RCA ? if yes, would it be worst ?
4. Most people like to use USB to connect their Computer to a DAC
a. if using a desktop, isn it beter to use optical if you have the option ?
5. what is the big difference between (normal, balanced and multibit output) why is there a decent price difference between them ?
A few question about headphones amps.
6. When using a system as powerful as the schiit jutunheim amp, is it possible to use, and have a great success using easy to drive passive speakers? in a 2.1 set-up ? in a 5.1 set-up ?
7. When buying DAC+AMP combo like the Schiit jutunheim or the Audio-GD R2R-11 is it possible to use JUST the DAC or JUST the AMP ? if someone want’s to upgrade down the line ?
a. Could a set-up like this work, using a juntunheim, ?
Blueray or computer > juntunheim > headphones
Blueray or computer > Jotunheim (using the Dac) > speaker Amp > 5.1 speaker set-up
and having a way to control if you want the sound to be output to your speaker OR your headphones ?
ps: i am new to all this and i'm trying to make sense of it all before actually shopping for audio gear
